- Joined
- 15 Apr 2018
- Messages
- 258
- Reaction score
- 1
- Country
Hi all
further to my previous post
I now find myself in planning to fit solid oak planks approx 120mm wide 18mm thick.
Due to the glue in the T&G the only viable way was to cut off the tongues and sand down groove edges to remove excess glue.
This means I can no longer float the floor.
As its a home office/summerhouse it doesnt have to be perfect.
The summerhouse is 3m x 2.3m
The floor is 18mm osb which is very level.
My original thoughts were to lay some polystyrene sheet type of underlay (as I have it) and fit the planks starting at the entrance (longest wall) and work towards the back.
I was intending to leave 8mm gap around the edges (but will change that to 10mm unless the moisture is below 6%, in which case I will increase it) and put a spacer of about 0.5mm between the planks both length and width.
As I cant secret nail I was just going to go through the face of the planks with a nail gun (16g d head)
Once installed I will then sand down and re varnish
Does this sound ok? or a complete nightmare?
Thanks in advance
Tongue and groove solid oak flooring in summerhouse.
Hi All I have managed to buy some second hand oak tongue and groove flooring for my summerhouse. It has previously been glued and taken apart so there is a bit of damage on some of the tongues and grooves. As said it it in the summerhouse (3m x2.5m) so it doesnt have to be perfect. It will be...
www.diynot.com
Thanks in advance
