Breathable Membrane Detailing
27 Sep 2011
I need to lay new breathable membrane down.
My neighbours roof adjoins mine and the existing membrane is one piece of fabric stretching the width of the two properties
To lay my new membrane, do I cut a straight line down the party wall, then lap the new membrane over or under the neighbours old membrane?
Do I need to overlap by a certain distance? Is anything else advisable to ensure a leak free job?
Sarking should be cut or finished on a rafter and lapped to at least the next rafter.
So you would decide which rafter to cut on, nail or staple it, then cut it. Then lap the new over the existing.
In your case, I'd cut the existing membrane on the second rafter in ie not the one up against the party wall but the next one. And then take your new membrane to the neighbour's rafter nearest the party wall.
Great, i jumped the gun and cut the existing sarking at the party wall
However, in my defence, I cut the sarking at the party wall because most of the sarking was so weak and torn in too many places. Also, I never saw your message before starting work :giggle:
So is the way forward to take the new membrane over to neighbours rafter past the party wall?
Fix each side into the nearest rafter on each side of the party wall to stop them sagging, then either take you new piece of membrane to the second rafter in on the neighbour's side or fit a cover piece to the second rafter on each side.
@^woody^ I cut and threw away all of the old sarking on my side of the party wall.
So right now, my roof has zero old sarking.
Unless I have misunderstood you, is my only option either to now
1. Fit the new piece of membrane to the second rafter in on the neighbour's side, then run the membrane along the width of my property
or
2. Fit the new piece of membrane to my rafter nearest the party wall. Then fit a cover piece in on the neighbour's side and then nail this on the rafter on my side of the party wall?
