- Joined
- 27 Jan 2008
- Messages
- 23,751
- Reaction score
- 2,679
- Location
- Country
The instructions are here nothing about RCD protection which does seem strange.
It can supply up to 3 kW so clearly a 6 mA DC is a bit pointless, I assume the problems are only after the unit, and supply side standard RCBO is fine. And since it only supplies the iboost+ if DC did bind it, in my case not a problem as don't really need the RCD protection on that circuit anyway. But surprised nothing in the instructions about RCD type.
Installation manual said:The Output of the Solar iBoost+ is a specially modulated DC output which must never be connected to the normal AC circuit. The Solar iBoost+ output must be the only supply to the immersion heaters and connected through a good quality, working mechanical thermostat.
