as title, doncaster cables are to launch a new range of twin and earth cables with preinsulated cpc. 1.0/1.5 and 2.5 initially but they hope to sell all sizes soon
"about bl++dy time"
"about bl++dy time"
Interesting, if it's true. Such cables are, of course, already required in many a country. Given that there is presumably a cost implication, I can't see such cables, even if/when available, coming into widespread use in UK unless/until it becomes 'required' (by BS7671).as title, doncaster cables are to launch a new range of twin and earth cables with preinsulated cpc. 1.0/1.5 and 2.5 initially but they hope to sell all sizes soon
It's not a totally one-sided issue. One advantage of having a bare CPC in between the two live conductors is that it appreciably increases the probability that something penetrating the cable and coming in contact with a live conductor will also come in contact with the CPC - thereby causing a protective device to operate."about bl++dy time"
in the video doncaster cables say they will sell it at the same cost as normal twin and earthInteresting, if it's true. Such cables are, of course, already required in many a country. Given that there is presumably a cost implication, I can't see such cables, even if/when available, coming into widespread use in UK unless/until it becomes 'required' (by BS7671).
Again, interesting, given that it presumably must cost a little more to manufacture (PVC does not come at zero cost).in the video doncaster cables say they will sell it at the same cost as normal twin and earth
Well, I've mentioned one (small) downside - and I suppose a related one is that it may, at least in some cases, delay the detection of cable damage/deterioration by IR testing.I really can't see a down side, I think it great.
I'm not an electrician, so I suppose I should keep my gob shut! However, I agree that a bare earth wire would be advantageous in such situations. Perhaps I must have missed something, but what is the advantage of having an insulated earth wire, apart from any proposed legal requirements?It's not a totally one-sided issue. One advantage of having a bare CPC in between the two live conductors is that it appreciably increases the probability that something penetrating the cable and coming in contact with a live conductor will also come in contact with the CPC - thereby causing a protective device to operate.
Indeed - and also, as I subsequently added, in some situations would enable cable damage/deterioration to be detected somewhat earlier by IR testing.I'm not an electrician, so I suppose I should keep my gob shut! However, I agree that a bare earth wire would be advantageous in such situations.
That's what I asked eric, but have yet to have a reply. As I said, the only (fractional) advantage I can think of is the avoidance of a need for G/Y sleeving at the terminations (and some people even discuss whether even that is actually 'required').Perhaps I must have missed something, but what is the advantage of having an insulated earth wire, apart from any proposed legal requirements?
As you will have seen, I acknowledged that - but do you think that that slightly increased 'convenience' is enough to overcome the (albeit small) 'safety' advantages I mentioned?Quicker, easier and cheaper to terminate.
It's not the same thing. This Earthsure or whatever it's called still had a reduced size CPC and it is an identifier rather than rated as insulation. The T&E in the south of Ireland has a full sized and insulated cpc, so is much bigger and more expensive. (It also can't be PVC for the past number of years.)Hasn’t this been standard in Eire for a while now ?
I'm very inclined to agree, which is why I always use sleeking but, as you will know, some people aree prepared to argue that it is not actually 'necessary' (or 'required')We should fit earth sleeve, however whether simply not fitted, or fallen off, I have seen many installations where it is missing. And the back boxes are not that big that it is not possible for an earth wire not to touch a live one.
One does if one wants a sensible price, but one can buy as little as 5m or 10m if one wants to. However, the cost is trivial - even 100m will cost only around £5 - £10, depending on size, and will 'last a lifetime'I understand why the earth sleeve is missing, one has to buy such a huge hank of it.
I was responding to JBR.As you will have seen, I acknowledged that - but do you think that that slightly increased 'convenience' is enough to overcome the (albeit small) 'safety' advantages I mentioned?
