Bathroom led light replacement
That LAP unit needs a 57 mm hole and the JCC needs a 73 mm hole
So it’s not suitable.
These units also use a 73 mm hole and you can change the bulb. Far better for everybody
You’ll also have to choose the IP bezel for the bathroom too
  • Thanks
Reactions: WSB
Thanks. When wiring up is there a particular In and Out or does it not matter?
In most cases it’s really straight forward.
The JCC and the KSR both use push fit connections. Just make sure you connect them correctly as shown on the units
  • Thanks
Reactions: WSB
From what I can see on the JCC with wires in place, there doesn't appear to be an in and an out.
Turn off circuit and push the grey tabs down and pull the cable out of the fitting
  • Thanks
Reactions: WSB
