Hope someone can help me with this one please ??
Competent DIY'er here, who's soldered dozens and dozens of copper fittings without any issue.
I've just cut out a section of vertical 15mm copper pipe that had a pin prick leak for months and had to use a solder ring slip coupling to put the new section in. I soldered the joints (not very well) and the bottom of the slip coupling joint leaked . I can only think it's because it was so difficult to get the flux into a slip coupling . I've resoldered it while it was still in place and the leak has stopped, but not being a pro, I'm not confident with the longevity of the joint ??
If a soldered joint is now watertight, will it stay watertight, or do you think I should get someone in to do the job properly ??
Cheers,
Graeme.
Cheers,
Graeme.
