Do you pva before dot n dan on bare brick?
Best thing to stick plasterboard to a steel lintel, the underneth?
Brick opening is a bit rough, could i fill gaps with morter, then dot n dab, or use something else, some gaps about 2 inch diff in the brickwork, that was cut out
exterel corner do you leave a slight overhang when a corner meets, to make up for ther adhesive?
regards
regards
