Our toilet is leaking (dripping) at pan connector/waste pipe when flushed. We are getting a full bathroom refit in May so need a short term fix in the meantime - can I just use sealant or is there something else we can do in the meantime?
Hi. Get some plumbers mait putty. Roll a sausage shape and push it around the pan connecter where it’s leaking. This is a common bodge that should last.
