- Joined
- 23 Jan 2023
- Messages
- 65
- Reaction score
- 0
- Country
Hello,
Installing a PFC to support the weight of the chimney above the steel so I can remove the lower sections on the chimney.
I have been instructed by calculations engineer to install pfc and 8mm steel plate.
Should the PFC sit at the back of the chimney so 3 sections of the brickwork sit on it or middle/front where only 2 sections of brick work sit on steel. With the steel plate above and 2inch into the wall.
Many thanks
Many thanks
