Can you please point me to the gas regs coverage part, that I can't find or I'm looking in the wrong place, I've seen copper gas pipes chased into walls flush with the blockwork then plastered over, my situation is more thought out and a lot safer than that scenario,If I can't meet requirements then I'll have to surface mount lots of extra pipework to get over it
Pipe will be protected with denso tape once testing is complete I may even fit a flat metal plate flush onto the wall, just to stop drilling through from my own side,It won't be forming a cavity, I know thje p[ipe is there but a future owner might not
Only supplying one 500mm 4 hob cooker, the amount of old bent lead mains that will come out should more than make up for any new pipe requirements, the amount of joins in that old lead pipe is quite substantial so there will be a significant distance of dead pipe being removed, I expect there might even be old gas light lengths hidden up under the floor boards as well.
Regarding party wall regs, I served noticed to my neighbours well before I started any work,I have no problems with the neighbours, it actually states works you don't need to tell them about, being fitting of new electrical sockets ,cable chasings ,replastering of the wall , refitting of kitchen units, I explained what I was doing and basically that's all I've done, structurally the wall will be stronger once finished even after the chasing as I'll be repointing any weak areas with new sand/cement joints, it will replace old lime joints that basically don't hold a thing together at the moment anyway,To have chased in a new 30 amp cooker supply would not be much different to my gas pipe chasing and that's not breaking building regs in the depths I have chosen, the main party wall no no's are when yoiu go right through with structural beams etc when removing walls or when cutting in new dpc's that go right through the walls
Denso13, I didn't take it as a trick question, nor did I ask anywhere how to do it, each plumber could come round and use their own favourite method, all the tape ,paste ,jet blue and Loctite 55 situations are perfectly acceptable , I asked what was the "Best " method for a permanent situation that suited my conditions best of all
