I am installing a dimmer switch to replace an existing switch. Currently there is a live (black) and a switched live (black with red tape on it) and an earth wire that is going straight to the wall frame. All OK so far.
My new switch has L2, L1 and a line with an arrow through it as well as an earth screw. i assume that I can connect some earth wire from the screw on the plate to the existing wall frame. However, where should the existing red and red/black wires be going to on the new dimmer switch.
I would be grateful of any guidance you can provide.
Thanks - S
Thanks - S
