New 8.5kW shower, about 18m from CU. Cable mostly surface mounted.
I know that 10mm cable would be a sound bet, but it's expensive and more tricky to work with. Is 6mm safe and acceptable?
The CU was new this year, therefore up to date. Is a slot in 40A MCB safe and acceptable or should a RCBO be fitted?
Would appreciate your advice, as I can't find a definitive answer via Google! Thanks.
