Hi
My daughter has single 11 radiators in her kitchen and lounge and after working it out they are way too small for the area. Her boiler seems constantly on trying to get to thermostat temperature.
I'm going to change them for her and was thinking about a straight swap for a 21. However I was wondering if it was likely to be a straight swap if I went for 22s instead. Obviously they'd be fatter. Problem may be that there's not much play in the pipes as they're coming up from floor. I'd also have to hang the new rad in exactly the same position and no doubt the wall brackets will be completely different.
Am I better just changing to 21s as there would hardly be any movement of pipes and they're only slightly under the btu rate (less than 100)
Thanks for any advice
