- Joined
- 27 Jan 2008
- Messages
- 23,680
- Reaction score
- 2,668
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
The 230 volt LED does publish a range of voltages but not the 12 volt version and I wonder if the battery voltage in a caravan is too high?
Battery voltage can raise to 14.8 volts with a stage charger but BS7671:2008 does state 14 volt maximum A721.55.4.1
Fitting a diode will reduce voltage 0.6 volts but then when not on charge it would be under voltage.
Has anyone used standard MR16 LED lamps off a battery and if so were there any problems?
