14.8 roof pitch
9 Aug 2016
hello, I'm achieving 14.8 degree pitch, am I worrying over nothing as it's almost 15 degrees or should I do what I can (substantial work required) to achieve 15 degrees?
I'm hoping for a slate looking finish, Cambrian or Eternit thrutone fibre cement slate also with velux
What are you using to measure an angle to tenths of a degree?
Normal tolerance is to within 1°
Sorry to be vague but I don't know. My neighbour and I are both building a single storey extension, he's got someone else in and slightly ahead of me, I'm not at that stage yet, ideally I want us to lay the roof as one, that's the pitch his builder advised. maybe he meant just under 15 degrees.
last time I had to do it , it was in minutes and seconds and a book of logs:notworthy:
Hey, don't knock the squinted eye, thumb and stick method. :mad: That was used long before you whippersnappers and your log tables and fancy trigonometry came along.
For the OP though, don't worry about one fifth of a degree - your angle finder is not that accurate anyway. And a degree either way won't make much difference
The deflection in the rafters would be more significant than 1/5th of a degree.
I had an issue with a roof that had cambrians specced years ago and Redland technical said they would probably be ok as low as 12 degrees anyway
You should be OK but if your using slate you should use permavent easy slate strips
Don't use Cambrians. I have had nothing but problems with my roof at 15 degrees. I would use a tile that has a few degrees extra to give you a bit of guarantee they might actually keep the rain out.
