I've just bought some new bath taps but am having a problem fitting them (the taps are shorter than the old ones and won't reach the connections to the pipes).
What I'm after is a couple of those flexible, braided hoses. Thing is, the tap's thread is the usual 22mm but the pipes are 15mm. Do such hoses exist - with the different measurements at either end?!
I'd like hoses with a thread at one end that I can connect to the taps and then a connection at the other so that I can connect to the pipes with an olive compression fitting - I don't fancy the rubber type.
Hope you can help!
Andy
Hope you can help!
Andy
