Yep, I agree that apart from item 43 there should be no code 4'sYou said building 5 years old and PIR done before 30st June 2008 which means tested to BS7671:2001 which was also in force when the building was built which means there can be no Code 4 faults.
I don't agree with the esc's guide to coding nor do I agree with the change in the NIC's guide. The NIC are now taking the view that if an installation has a code 2 it cannot be signed off as satisfactory. Why have a code 2 if it means the same as a code 1?So if we said for example.
Code 1 Requires attention
Code 2 Requires improvement with labels earths and locks
Code 3 Unable to test
Code 4 Low priority labels missing
Then it would seem OK (Note dropping of Urgent) but if one was to follow the Electrical Safety Council coding then with so many code 1 faults the building should have been closed down.
IMO a 1 code means that what has been tested or inspected is unsafe. It is also likely to start a fire or injure someone/live stock.
A code 2 means that what has been TOI is far from ideal but it is safe to use. It requires improvement ASAP.
A code 3 means requires further investigation ASAP
A code 4 means that the item TOI does not conform to a minor change in in 7671.
I tend to agreeTo have so many RCBO does not trip in time faults rings alarm bells as I have so many times seen those without their C&G2391 test RCD’s at tripping level rather than 5 x tripping level to measure time and being such a simple job to re-test I would start there to see if it has been done by a skilled or semi-skilled person.
Also what you show is not really a schedule of test results which would show RCD time in ms etc. I had a similar problem with a hotel and I had to make it very clear that without a copy of the schedule of test results I would need to do the PIR again this is still on going.
Eric
The PIR is very comprehensive and the schedule of test results are about 30mm thick!
There are quite a few obvious typo's but having entered hand written test sheets into Amtech I can relate to them.
