Now the 17th regs have been in for awhile, i was just wondering what is working out the "best working practice" in relation to consumer unit, and circuit protection.
We are just starting a rewire on a 4 bed detached property that has just been extended, some exsisting cable routes will be reused so normal twin and earth will be used and these circuits rcd protected,
My concerns are regarding nuisance tripping which could be caused by outside lights etc. are these better on seperate circuits with rcbo's
We also need to install an air pump for sewage treatment plant, instructions say to install on a seperate circuit, but am concerned that if for some reason it tripped the circuit we wouldn't know, my thoughts are to spur it from a ring main via an fcu (the pump is only low wattage)
The same concerns relate to smoke alarms, in the past i've connected them to the lighting circuit, is this acceptable ?
I've also been searching the forum with limited success regarding the use of junction boxes under floorboards for lighting circuits, are they classed as accessible ? I could loop into the light switches but was just thinking of saving cable really, and already numerous cables to some switches.
Any help much appreciated
