- Joined
- 3 Jun 2016
- Messages
- 128
- Reaction score
- 3
- Country
I'm in the process of buying a 1930's detached house. It's in good condition but the survey highlighted a damp reading on one of the chimneys in the living room. I got a damp survey and they said the same, recommended taking 1m of plaster off and injecting and putting anti salt plaster on or something like that. They also mentioned raised damp readings under floor but no current damage apparent but noted that they could only lift a small section of floor.
I took my father for a look and we noticed plant pots covering most of the underfloor air vents, the chimney internally had a electric fire filling the opening and no internal air vent. He bounced a little on the floor and said is bounced back so though the timber was good. The other side of the wall runs down next doors side entrance, they allowed us to take a look. The brickwork along that wall is not in as good condition as the rest of the building, minor spoiling (is that what its called) where the surface of a patch of bricks is a bit rough but not too bad, the wall looked a bit damp in the same patch. I spoke to the neighbour and he said the wall didn't get much sun. I noticed that the side entrance had a small bush half covering it's entrance so probably not much airflow. Also the neighbour moved some tall rubbish bins which were infront of the damp patch.
So I'm not currently convinced about pulling plaster off (no internal damp patch or smell). I'm thinking that moving the plant pots, maybe changing the air vents to newer more efficient ones, cutting back the bush, asking the neighbour to move his bins somewhere else, and putting a vent in the chimney breast internally might help to resolve the issue. Not sure what to do about the minor spoiling on the bricks though as I've read using breathable coatings to stop water ingress on solid walls isn't and ideal thing to do.
Thoughts ?
Thanks in advance.
Thoughts ?
Thanks in advance.
