hi i have recently brought a 1998 astra van 1.7td , it had a problem with the heaters not working and from time to time it would overheat. Anyway i replaced the thermostat and also flushed the rad through. Foundheater matrix pipes blocked with crap so cleared that and got water flowing freely around the system.
Only problem is that the top rad hose gets very hard from what seems like to much pressure, if i unscrew the water filler cap slightly and release pressure the hose goes soft again.
Would this be the headgasket gone causing this or is there another alternative ?
all help appreciated
