Hi thanks for all advice, have found a possible route for 6mm cable.
Consumer unit then understairs otherside of stairs have just finished laying + grouting replica 40mm thick flagstone flooring.
Chisel out soft cement along the edge of wall and floor. 40mm + cement bedding run cable along and cement/grout over and come out under kitchen / hob unit.
This will give me a 6mm + 2.5mm for the original hob that requires 10.8kw and 50amp conn.
However only space for 1rcd in consumer unit ? I presume a new consumer unit or 50 rcd with 6mm + 2.5mm feed to hob
