- Joined
- 12 Nov 2009
- Messages
- 6
- Reaction score
- 0
- Country
Hi Guys!
Hope someone out there can help us out.... a while back we had an electrician in to install some downlights.. and to say the guy ended up being a total nightmare is an understatement... I have no idea where to get a reliable electrician so I thought I'd hit the internet.
about a month ago, my fanch 2gang touch plate dimmer went on the fritz.. 1gang wasn't working... there is an led on each gang plate that is lit when it is recieving power... thisi s an assumption based onthe fact that one of the plates led doesnt light up and subsequently the lights associated with that plate are inoperable.
so I bought a new dimmer, just a 2gang 400w dimmer.. nit so fancy this time.. a push button one..
ok so now the problem.. I took the current switch off the wall and discovered it had less positions to position the cables than the new one... it has 4 (2 on each gang) and the new one has 3 on each.
So I wired it mirriring what i had seen before removing the original switch.. and 1 half of the lights worked (just like before). I was unable, after trying various combinations to get the other switch working.
The first switch is as follows (x represents a cable recepticle,with no label)
2x ____ 1x | 1x _______ 2 x
the left side had a black cable in 2x and crossover cable in 1x
the right side had both crossover and brown cable in 1x
the new switch actually has labels!
L2 ____ L1 _____ C | C _____ L1 _____ L2
so I've left it as
black in left C, crossover in Left L1
crossover and brown in right C
Not many other combos worked (at all). There is a spare taped off gray wire and i tried it in a couple of combos but it did nothing so I taped it off again.
Finally the question.... how on earth do I get both circuits working agian!!!!!
so I've left it as
