i wonder if anyone can give me some advice on an issue i have.
I have a 2 gang dimmer in my kitchen. i live in the UK.
On each gang of the dimmer i have 6 x 50 watt gu10 halogen bulbs.
What seems to happen is that nearly every time a bulb blows, it blows out the dimmer aswell. So that my dimmer switches are now just regular switches (they are on full beam all the time.
I have replaced the dimmer and it has happened again.
On the back of the dimmer it states that the maximum wattage on 1 gang should not exceed 250 Wattts. However i ahve 6 x 50w bulbs on each gang which is 300 Watts.
I thought that this was the problem, although someone has suggested that i need fused gu10 bulbs.
What do i need to resolve this issue?
an electrical retailer has offered me by email:
"CKP2 x 500PC 2 gang x500w/400va polished chrome dimmer.
85.50 -40% discount = 51.30 + vat"
which i think is a two gang dimmer with each gang being able to have a load of 500w which is obviously more than the required 300w that i need. Do you think that will do the job??
however he also states that:
" If using mains & gu10 lamps, the lamps must be fused or else every
time that a lamp blows, it will destroy that side of the dimmer and possibly all the way back to the board."
So do you think i need both, or is it just either the fused gu10 bulbs?
Or a two gang dimmer that can handle the load of 300 watts? If its the dimmer would the one the retailer has susggested dot the trick????
This dimmer is pretty expensive so i definately do not want this to blow aswell.
thanks in advance
Tinny
thanks in advance
Tinny
