But IT DOESN'T FIT !!!
The lift is built to order, and we gave exact measurements for the purpose built shaft, which is 1250mm deep. But the engineer said he needed 1270mm. The lift platform was catching on the nearside wall.
The drawings give a tolerance of 20mm either side of the platform but the engineer said they need 30mm. The extra 10mm each side appears to be for the wiring loom to cross over the shaft.
The only thing for it was to knock out the wall and lintel above to give the clearance needed. The concrete lintel and blocks installed 2 weeks ago have now been replaced with a wooden lintel. There will have to be some additional support stud work installed around this on the ground and 1st floors.
The really annoying thing is that this was completely avoidable, even up to the point last week when the lift co. surveyor came out, measured the shaft and signed it off for installation.
I shall be contacting the lift company for redress!
At least it now fits. Just!
A closer view of the wiring.
There is also a problem with a faulty safety sensor, so the lift won't be finished until next week.
