Front Intermittent wipers not working on 2000 (W) Hyundai Accent 1.5 CDX. The wipers work fine on normal and fast speeds and park correctly when switched off so I'm sure there is nothing wrong with the motor or the park switch within the motor unit.
My best guess is that the fault is most likely with the intermittent relay or an open circuit in the wiring.
Problem is, I can't find the relay! Does anyone know where the relay is located - or is it integrated into the switching unit on the end of the stalk?
Also, does anyone have or know where I can find a wiring diagram for this model?
Any suggestions or help appreciated!
