Now I'm just getting irratated... Installed the clutch master cylinder. Bleed the damn thing with about 100 pumps. Not 100% positive if all the air is out. Got some pressure back in the pedal but it doesnt feel at all like it used to. Still will not go into gear...
Now I'm thinking back to when the whole thing happened. drivving... feels a little pop in the clutch... let go of clutch pedal... slow down for red light... push on clutch pedal... pedal will not go down... and can't put into gear... after that look at clutch master cylinder and fluid leaking out... Wouldnt one assume this is a clutch master cylinder problem and nothing else?? Or could the clutch master cylinder be one fault of many in a chain reaction. or the clutch master cylinder just being a coincidence and the real problem being something else.
or do I just need to bleed the clutch properly... This is beginning to drive me nuts. may have to bite the bullet and bring it in.
