2006 Renault Grand Scenic Heater Blower
Discussion in 'Car Repairs / Maintenance' started by taxi1161, 4 Apr 2012.
  1. taxi1161
    20 Jan 2012
    36
    Thanks Received:
    Merseyside
    Country:
    The heater blower switch on my 2006 Renault Grand Scenic only works on number 4. I have pulled the plug out of the resistor and only the purple wire terminal is all burnt. If I just replace the loom and the plug, will the blower switch then work on numbers 1 to 4 or do I need to replace the resistor as well.any information wiil be most appreciated.
  2. Peter.N.
    26 Sep 2006
    1,587
    Thanks Received:
    236
    Dorset
    Country:
    You could try cleaning up the pin and socket that's burnt, its obviously had a bad contact which has caused it to heat up, even if you can only get it to make good contact for a short while it should answer your question.
    Peter
  3. gregers
    28 Mar 2008
    6,302
    Thanks Received:
    499
    Sussex
    Country:
    i would replace the resistor aswell.
    • Thanks Thanks x 1
  4. taxi1161
    20 Jan 2012
    36
    Thanks Received:
    Merseyside
    Country:
    Have cleaned the pin and socket that has burnt ( other conections are OK) and reconnected it but blower still only works on 4 With regards to the resister with working through a small hole in the dash and cannot see anything and working by feel.. I could probely remove the resistor by undoing the torx screw ( only one ) but I doubt I could replace it. Is it the burning of the connector plug or is it the resistor that stops the blower working in positions 123 ? Also is it possible to replace the resistor though the small space in the dash ?
  5. Peter.N.
    26 Sep 2006
    1,587
    Thanks Received:
    236
    Dorset
    Country:
    If you have managed to make good contact with the burnt connections and it still doesn't work then, yes the resistor needs replacing.
    Peter
    • Thanks Thanks x 1
Loading...
Share This Page
