I need to get a wall built ans eventually rendered - 22ft long, std 6ft high. it's not a load bearing wall, literally just needs to stop a sliding electric gate (on wheels on a track) from toppling over - there will be a wheel mounted at the top and the same on the other side of the gate but attached to a fence post of the existing fence, so in effect, the gate will slide back between the fence and the wall.
I've had 2 builders look at the job. I must also point out that founds will be only 12" as there is soil & water pipes & an electric cable running directly beneath where the wall will be.
1 builder says 4" block with peers at each end, the 2nd one says no way, it'll wobble and crack - 6" block all the way thru, ie. no peers required (which will actually save me 2" of space).
What do I do???
Thanks for any advice
Dean
What do I do???
Dean
