240 v light in shower room
22 Apr 2007
London
I would like to put a 240 v Mirror with a light in a shower room. The mirror will be above a sink and within 1.5metres of the shower which has a fixed outlet. Whole house is protected via a crabtree cu with 30m/A main RCD.
Any advice would be appreciated
Be careful.
Comply with Part P.
Isolate a circuit before working on it.
Wear rubber-soled shoes.
Be kind to your mother.
Or did you have more specific advice in mind? :evil:
Lots of things are that shouldn't be and aren't that should be. Are you suggesting I change the whole cu for a mirror in the bathroom. CU was aquired with the house so I find your advice a bit drastic.
Well that's a very sound existentialist reminder of our reality, but you can hardly expect experts on the forum not to tell you when something is wrong.
I believe that sm1thson was pointing out that it's unwise for all of the circuits in a household to be protected by the RCD.
It's more normal, for specific reasons that you might or might not be interested in, to put the kitchen sockets, downstairs sockets, and an electric shower circuit (if it exists) on the RCD side, with lighting and dedicated high-load circuits (such as cooker and immersion heater) on the non-RCD side. Oh, and the freezer on the latter.
It's only drastic if your installation is drastically wrong, and you can hardly blame anyone here for that.
dont mean to be picky but unless you know your incoming earthing arrangement ie is it a tt then it is acceptable to have everything on an rcd
Er yes, good point. I was carried away with interpreting sm1thson's post. :oops:
no probs softus, but i was just thinking, if the house is protected by a 3oma rcd and it is a tt system should really be a 100ma rcd for lighting and 30 for the sockets,
Or have two RCDs.
Kitchen sockets on one and kitchen lights on the other. Then when the kettle tips boiling water over you and the socket trips out you still have lights to find the ice cubes.
For what it's worth, I concur.
bernardgreen said:
Or have two RCDs.
Shirley that makes the prospect of nuisance tripping on the lighting circuit even more of a nuisance? :confused:
good point then when the whole lot trips you have another switch that fires up the generator so you can watch the telly :LOL:
That would be incredibly stupid and pointless.
If the circuit has tripped there is a fault.
Energising it from an aletrnative supply will only liven up the incomming side of the RCD and the circuit will still remain dead
rf lighting
please note the laughing symbol at the end of my post not intended as a serious comment. :rolleyes:
