Hi I just wanted to check if this would be ok
What I wanted to do was put in a 2ft Tube in the cupboard under the stairs, which would be running off a FCU with a 3 amp fuse in.
The way I was going to do it was:
To have a surface mounted unswitched FCU running as a spur from the socket in the dinning room (which is on the other side of the wall, of the cupboard), by using a piece of 2.5mm T+E, going from the back of the socket through a hole in the wall and into the back of the FCU.
Then to run to length of 1.5mm T+E from the FCU to a 20amp 4 terminal JB.
Then I was going to run a length of 1.5mm T+E from the JB, to a surface mounted 1 Gang Light Switch.
Then I was going to run another length of 1.5mm T+E from the JB, to the 2ft Tube.
And I was going to put a 3amp fuse in the FCU, and clip up all of the cables using 1.5mm Tower Clips.
So would this be ok
So would this be ok
