Hi all,
I'm hoping that someone might be able to help me with a problem I'm experiencing with my central heating/hot water system. The valve is Honeywell V4073A three way.
Mostly the system works fine, except for one condition.
The symptom is that when the CH is operating, and then HW is called, the 3 port valve doesn't move to the mid position - it just stays on CH.
However, if CH is cancelled, and HW called, the valve will correctly return to HW only position.
Then, if CH is called, the valve will correctly move to the mid position and stop, providing both HW and CH.
The boiler and pump are working fine.
I'm not certain what might be causing the problem. Having looked at the schematics, I'm wondering if a failed micro switch (SW1) in the valve might cause the problem?
What doesn't help is whether this is a new or existing problem.
Usually we have called for HW before CH, and it's only recently that we noticed that HW isn't available if the System was in CH mode first.
The control panel show the correct lighting, indicating that all is well, and the boiler etc operate just fine. It 's just that the valve will not return from CH to mid position.
Any suggestions would be gratefully received,
Many thanks
Tony
Many thanks
Tony
