hello, can some one please send me a wiring diagram for the following; 2 separate lights (in a hallway) controlled by 3 switches (one intermediate). Thank you in advance.
Have you looked in the 'sticky' references at the top of these posts, there's all kinds of wiring diagrams. If you're using 3 core as a strapper cable between the two 2 way switches. The wires will be com to com (red) L1 to L1 (yellow) and L2 to L2 (blue). Basically you cut the yellow and blue and put the ends into the marked terminals of the intermediate switch. Although the red does not need to be cut, it is easier to cut it and join the ends in a choc block.
hope it helps
