Worcester 40 cdi is loosing pressure but has no leaks , if I fill the boiler to exactly 1.5 bar and then run the hot tap for 5 mins you can see the pressure gauge is loosing pressure , when it switches back to heating it has definately lost some pressure , is this going to be the DHW heat exchanger or is there another part where the heating water could be passing into the hot water ???????? Cheers Guys
