can anyone tell me if it is possible to adjust the idle rate on my corsa as it only idles at 650 R.P.M. and it stalls at the drop of a hat. Once on the move it drives brilliantly and pulls well
Yes can be done, BUT you need tore program the ECU... Will be done under warranty if you take it to your local dealer... there is a re work for that problem..
Its a re work. That basically means that if a customer complains of a known problem, then it is rectified FOC whether the vehicle is under warranty or not.
