I am having a hot tub delivered and I want to make a connection in the loft between 6mm swa and 10mm t&e, I intend to run the cables along the rafters so no insulation involved.
The reason for the 10mm t&e is that I had an extension built and had a 50amp breaker installed next to the CU with 10mm t&e put into the loft just in case I ever wanted to have an electric shower installed. I want to use these as the swa isn't long enough to go straight to the CU and I don't have the space in the CU anyway. The 10mm t&e is approx 4m from the intended connection box to the breaker
The hot tub has a 40amp external isolator already set up, with 20m of 6mm swa (just needs connecting to the tub)
I will terminate the swa to a steel box (with lid) fixed to a rafter using a 20mm gland, and earth the swa and t&e to the metal box. The live connections will be made into 100amp connection blocks (spare ones in my toolbox)
My questions are
Is it correct to connect 6mm swa to 10mm t&e
Am I OK to use the 100amp connection blocks
Thanks in advance
Paul
My questions are
Thanks in advance
Paul
