75mm timber connector force
10 Nov 2005
Kent
Using some 75mm double sided timber connector and struggling to get them to close up.
Am I just not being tough enough
Got to get some longer bolts as did not manage to fit the external washers. And hire a 90deg drill
they are very awkward are your bolts threaded enough do you have a couple off mm clearance on the bolt
Now do these washers go flat as I,m putting more than the torque of the bolt and the square washers are bending
