Dave - capacitance has absolutely nothing to do with how much current passes through a human body. If you believe otherwise, please provide an explanation.
Your shoes are an insulator aren't they
dingbat - any chance you could post a few scans of some choice pages - maybe he can be given some technical arguments...
His 'punctuation', I find, is really quite 'annoying', too.
No negative comment has come back from any of the above!
Well i'm glad that's nice and clear then."into the human body (capacitance)..." The human body is first filled to its' 'capacity'.
"through the human body to earth..." Then the human body has a 'resistance' to the flow of current to earth.
If for example you were stood on a block of polystyrene when coming into direct contact with a live conductor, the human body will simply fill to capacity with earth leakage current.
If on the other hand you were for example sat in a puddle of urine when coming into direct contact with a live conductor, the human body will have a resistance to earth and therefore current will pass through the body.
Totally. I have absolutely no idea what you're saying!Therefore, I'm sorry but you have misunderstood what I was saying.
Surely if you were going to write a book like this you would have someone check the work/proof read it?
I am the proud owner of a set of City and Guilds qualifications that all have something in common apart from the fact that they all bare name, they also include the phrase "no higher grade can be achieved in this subject".
In normal circumstances that would happen, however in this instance the publisher is one of those 'pay for everything yourself' types where the publisher neither checks what is printed or cares if the book sells at all.Surely if you were going to write a book like this you would have someone check the work/proof read it?
All technical books contain legal disclaimers, because if not, the author and publisher would most likely be held liable for any damages caused when someone (mis)uses the information provided. Even books which are carefully checked by many people can still contain mistakes (just look at BS7671 for a start).As far as I know these two books are the only books on the subject of electrical installation currently in print that do not contain any form of 'legal disclaimer'
