Evening all,
We've recently moved into a new house and have been finding that at certain times of day we get quite a bit of odour in the bathroom, the soil pipe comes through the external wall and then is boxed in to the toilet, I stripped the boxing off and found the odour is coming from opening in the wall where the soil pipe passes through, initially I tried sealing around the pipe where it comes through the wall with some expanding foam, this just moved the odour so that it came out of a hole further up the wall. So I thought I better find the root cause and where the pipe is venting into the wall.
I thought perhaps the seal where the horizontal pipe enters the stack might be leaking, but after breaking the mountain of mortar out of the wall around the pipe I found that the problem wasn't there at all, it all seemed fine and there wasn't anything leaking.
But then I noticed a hole where the soil pipe goes into the ground, and this is where the odour comes out, but the stone work on the wall around here is quite poor, I suspect what's happening is the odour was coming out here and creeping into the wall and then coming up the wall through the stone work before leaving in the bathroom, would that make sense?
I've had a poke down the hole with a screwdriver and it seems to be quite deep so I'm thinking I better take the stack off and redo it.
What sort of socket should there be? or is it OK to just grout the hole up and then put the soil pipe back and grout around that too?
Some pics to give you an idea:
Annoyingly it's been put together with solvent weld fittings too, is there a way to separate these without breaking them or cutting the pipe?
Excuse the loose stone, haven't got any lime mortar yet and I'm not just filling it with portland cement mortar like the previous builder/bodger, so found some stones to fill in most of the hole.
