I have a 10 year old Accenta G3 system which has been installed in a simple 3 zone set-up.
Just recently it has started to make a short 'blip' noise whenever a button on the panel is first pressed. By this, I mean that whenever it is either activated, or deactivated, I hear a short 'blip' from the panel when the first button is pressed. It is only when the first button is pressed that the noise happens.
The panel works perfectly well and there are no obvious signs of damage, or overheating, or loose wires etc.
Should I be worried? Is this a known problem?
I have done a Forum search and not seen anything relevant.
Thanks for reading ...... Michael
