Quick question, any advice much appreciated. We have a Glow-worm fuelsaver F. Our actuator valve that control the supply to the storage tank, is not working. How can i tell if it may be the thermostat on the hot water tank that is faulty ??
Rich if it clicks in the right place, the thermostat is thousands of times less likely to be at fault than the motor in the valve. I don't normally even check them!
