Adding a socket / extending the ring main
15 Jan 2007
I’d like to move a socket which is behind a cabinet 8 inches further along the wall so that it is accessible for use. (The socket already feeds a spur so I cannot solve the problem that way).
How do I extend the mains cable to reach the new socket?
Should I use a junction box like this http://www.tlc-direct.co.uk/Products/MK1130.html and can I bury it in the wall?
Many thanks
You can use the junction box as indicated, but unfortunately all JBs have to accessible, so you can't bury it. But as it's behind a unit I wouldn't have thought that much of a problem.
This work would be notifiable if it's in the kitchen.
You could use a blank plate over the existing socket and extend each cable out to the new socket using connectors or crimps.That way the joint will remain accessible
Sarah
Can I crimp and then plaster over the old socket?
No - as the cables to the new socket would not be in the correct zone (ie where they would be excepted to be - vertically above)
EDIT:To fast RF ;)
Ah! Thanks
This has given me a further thought. I can solve the problem by moving the socket vertically - rather than horizontally across.
Crimping and plastering OK now?
It depends...
Like RF said, you can't leave cables hidden without some way of making their presence known (i.e by having a socket to the side of it if the cable is routed horizontally or directly above/below if the cable is routed vertically).
If the feed cables come in and out from the sides then moving it up will mean the cables will no longer be in safe zones. (unless the feed for the spur and the socket follow the same horizontal plane as the socket you intend to move).
If the feed cables come in from above but the cable supplying the spur goes horizontally then you are fine as long as keep the cable to the side of the spur until it is below the other socket and then go up.
Explain which way the cables are routed and we can give you better advice.
Davy
The cable run will remain in the same plane.
i.e the exisiting cable runs vertically up the wall to the exisiting socket, I plan to crimp at this point and locate the new switch vertically above.
