adding a towel radiator
14 Apr 2006
Hampshire
i am just putting in a small bathroom on 2nd floors (ground, 1st second fllor) boiler on ground floor. it transpires the central heating system up there only has 15mm pipe. someone said i would have trouble getting an extra radiator on. the current system has 2 small single radiators and one small double radiator (70cm by 50cm) , i intend to add a small towel radiator 60cm by 60 cm (1256 btu) can anyone see any problems.
cheers jon
Try it and balance your system.
If it does not heat up then change the pipes going upstairs to 22 mm :D
I wouldn't have thought it would make any difference on a small system such as you say you have. 15mm pipe will handle up to 14000 btu (4Kw)
