Hi Guys,
been reading lots of threads on here for months but thought about time I took the plunge and asked my own question.
I have a CCTV system with is currently just plugged into the ring main in my garage which runs off a single RCD Consumer Unit.
Im often away at weekends and a couple of times now I have returned to find there has been a fault in the garage somewhere and the RCD has tripped and turned the power off including of course my CCTV.
In the New Year I will be getting a spark to alter the set-up so the CCTV is on its own circuit and in turn if there is a fault the CCTV will remain on if the RCD in the CU trips.
I would like to ask your opinion for the simplist way to acheive this set-up, before my spark goes and suggests a more costly method (which he had done before) and which isn't needed.
Thanks in advance.
Thanks in advance.
