Adding lights to outside circuit
31 Dec 2003
I have recently bought a house that has three outside lights professionally wired with armoured cable buried in the ground. The lights are wired in series i.e. from the mains switch the cable runs to Light 1, then from Light 1 to Light 2 and from Light 2 to Light 3.
I would like to add one or two more lights to the circuit but to minimise the trench digging I would like to add the extra lights as a spur from Light 2. Would that be OK?
Snowsride
so long as:
they are NOT in series,
the cable is capable,
you use wire armoured cable
you use a suitable weatherproof connection to the light
then probably
80V lamps???
Snowsride - don't take offence, but the fact that you think your lights are wired in series makes me concerned that you don't have enough knowledge to decide if the circuit can handle extra lights, nor to correctly and safely connect more SWA cable into it. I think you should get an electrician in, but by all means dig the trench yourself - this will save you money, and won't upset the electrician.
He doesn't mean in series electrically, he means they are wired in sequence.
"In series" perfectly describes lights that are wired one to another, but of course not in the electrical sense.
I've been found out - I am not sure they are wired in series - I just used the term I have heard to describe how I have seen the cable connected!
I belive Securespark's 'sequence' description is correct i.e. Mains to Switch, Switch to Light1, Light 1 to Light 2, Light 2 to Light 3.
Imagine a straight line with the switch at one end and with 2 lights at intervals along the cable terminating with Light 3. The cable is wire armoured.
So can I connect one or two more extra lights from the terminal in light 2? The circuit would then look like a Y with light 2 at the junction of the Y.
Snowsride
sure as long as the knockouts are there to properly fit the armoured
you must use outdoor (CW type) glands
if there isn't a spare knockout at the light use a resing filled tee joint kit
Check the size of the fuse and make sure the circuit is protected by a RCD
Sorry - I tend to take a fairly precise, purist view of terms like "series" and "parallel" - I find it's best in the long run...
Thanks to all contributors and no offence was taken re. comments about my terminology. Hope to have no more questions that will expose my ignorance!
Regards
Snowsride
