- Joined
- 24 Apr 2024
- Messages
- 4
- Reaction score
- 0
- Country
Hi. I am having a new kitchen and am replacing a gas cooker with an electric oven, hob and extractor fan. The cabling for these will run in trunking behind 5 cabinets before reaching the oven etc, so I want to check the cables are adequate before I put the cabinets in place. I plan on one 6mm t&e and one 4mm t&3. The 6mm for the hob and the 4mm for both the oven and the extractor. Given the values below, does this sound adequate? I will be getting an electrician to actually wire the appliances in and to connect the other ends to the consumer unit. Thanks.
The oven is a 3.49 KW,
The induction hob is 7.4KW,
The extractor fan is 158W.
The run from the CU to the appliances is around 5m.
