I want to put power into the brick built shed. It will be 6mm twin & earth from the CU to the outside/inside wall then into 4mm SWA cable and come down the wall into a waterproof outdoor socket on the wall and then out to the garage and the run is about 25m..
What side of the CU should the cable be connected, 30mA or 100mA RCD side on a TT system?
I want a couple of double sockets and a couple of lights up. What are my options in the shed to connect the 4mm SWA to?
