dx90 said:Does anyone own or know if the FLUKE 17B Digital Multimeter with AC Transducer Clamp is any good?
dx90 said:Yes it was on Ebay.
If you search for, FLUKE 17B Digital Multimeter with AC Transducer Clamp you will find the one that I'm intrested in buying.
If it is a ripoff, fake then let me know and I will stay well clear of it.
dx90 said:Will do. Thanks for the warning.
Do you know of any good cheap makes that are ok?
The mains lead of a friend's laptop power supply "exploded" at the end of the strain relief. Examination found virtually no French Chalk lubricant between the inner cores and the outer sheath which results in the lead being less flexible than it needs to be and as a result the conductors and their insulation fail prematurely where the cable is flexed repeatedly.
