I'm planning a kitchen renovation, and are looking at different heating systems.
The kitchen is in a 1980s extension to the original building, and has a concrete floor. It is currently heated via an electric plinth fan heater, and is open plan to the living room, so gets some heat from the log burner.
I'm are considering the following options, I'd love to know the advantages/disadvantages of each, and if there are other options which I haven't thought of. There's not really room for traditional radiators, but there is plumbing easily accessible.
The electric system would be easier to install, and be thinner than a plumbed in system, but have higher running costs, right? I'm leaning towards a plumbed in system, because it will keep things simpler overall, but I'd like to know if the retrofit systems are any good.
I don't think that (edit) that I should go for (/edit) a full plumbed in system. These are around 50mm thick, right? I think that the expense/disruption of installing that would be too much.
Thanks for the help,
Dan
- 1. Plumbed in radiators under the new cabinets
2. Plumbed in under floor heating (I've found 'retrofit' systems which are only 15mm thick, and appear suitable for my requirements)
3. Electric underfloor heating
Dan
