Wet patches are on both corners of each window that leaks. It's only 3 out of 20 windows with this issue, and the others don't seem and different in terms of placement.If you have spirit level, perhaps sit it on the cill see if it angles down to your wet patch (sounds wrong).
While they're in the same position as the old, I presume they didn't move as it would have left more cavity exposed than the widest trim they had on the van / the internal window board depth wouldn't allow for it.would have expected those windows to be brought forward
Question remains:
How do I deal with the installer? If I dump water down the rebated holes and nothing comes out of the cill, is this enough to demonstrate inadequate install?
Problem is, if these are moved forward, then every window in the house (are at least on the same side of the house) will need moving forward to suit, or it'll look sh1te.
Front of the house is like a picture a kid would draw. It's a lot of work to move them:
E.g.
![Screenshot_20221222_165436_Chrome.jpg Screenshot_20221222_165436_Chrome.jpg](https://cdn.diynot.com/data/attachments/290/290085-568434b1a3640a938398700cd308bc87.jpg)
