hi
Ive got a plane simulator in my loft area and I need to fit an overhead panel above where I sit at the computer.
The overhead panel will be approx 670 x 718 x 125 mm and weight about 15kg.
It has fixing on the sides or on the back of the panel where I can screw it to something.
I need to get something to fix to my rafters that hangs down and fixes to the panel. I was thinking a metal strips of some sort with holes in which I can screw into the panel using the hole which gives me the best height of the panel.
Do you have any ideas or exactly what I should use or any other suggestions.
Is there a certain thickness of metal i would need? I'm guessing I will have 4 of these.
Thanks in advance.
Thanks in advance.
